Zum Hauptinhalt wechseln
HP EliteBook x360 830 G7 Battery Replacement
Was du brauchst
  1. HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: Schritt 1, Bild 1 von 3 HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: Schritt 1, Bild 2 von 3 HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: Schritt 1, Bild 3 von 3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Battery Replacement, Disconnect the bundled cable connector: Schritt 2, Bild 1 von 1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: Schritt 3, Bild 1 von 2 HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: Schritt 3, Bild 2 von 2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: Schritt 4, Bild 1 von 2 HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: Schritt 4, Bild 2 von 2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: Schritt 5, Bild 1 von 3 HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: Schritt 5, Bild 2 von 3 HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: Schritt 5, Bild 3 von 3
    • Remove the battery from the laptop.
Abschluss
Emily Kaplan
217 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 53
Insgesamt: 930
