Zum Hauptinhalt wechseln
HP EliteBook x360 830 G7 RAM Replacement
Was du brauchst
  1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: Schritt 1, Bild 1 von 2 HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: Schritt 1, Bild 2 von 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: Schritt 2, Bild 1 von 3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: Schritt 2, Bild 2 von 3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: Schritt 2, Bild 3 von 3
    • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
  3. HP EliteBook x360 830 G7 RAM Replacement, Remove the RAM: Schritt 3, Bild 1 von 1
    • Push down on the two latches on both sides of the RAM to release it.
    • This will allow you to remove the RAM and replace it with no issues.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 13
Letzte 30 Tage: 55
Insgesamt: 1,104
