Zum Hauptinhalt wechseln
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
Was du brauchst
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: Schritt 1, Bild 1 von 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: Schritt 1, Bild 2 von 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: Schritt 1, Bild 3 von 3
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: Schritt 2, Bild 1 von 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: Schritt 2, Bild 2 von 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: Schritt 2, Bild 3 von 3
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: Schritt 3, Bild 1 von 2 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: Schritt 3, Bild 2 von 2
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 1-24, Maness Fall 2015 Mitglied von Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Mitglieder
14 Anleitungen geschrieben
2 Kommentare
where can i buy a replace cage for the hard drive?
Thomas Dickson - Antwort
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 68
Insgesamt: 8,389
