Zum Hauptinhalt wechseln
Einleitung
This guide is to be used in the case of a power supply that has begun to give out. Power supply failure can be recognized through symptoms such as slower run time, or issues with pace of processing,
Ersatzteile
Keine Ersatzteile angegeben.
  1. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: Schritt 1, Bild 1 von 3 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: Schritt 1, Bild 2 von 3 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: Schritt 1, Bild 3 von 3
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: Schritt 2, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: Schritt 2, Bild 2 von 2
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Power Supply Replacement: Schritt 3, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement: Schritt 3, Bild 2 von 2
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Power Supply Replacement: Schritt 4, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement: Schritt 4, Bild 2 von 2
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Power Supply Replacement, Power Supply: Schritt 5, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement, Power Supply: Schritt 5, Bild 2 von 2
    • Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
    • Lift up on the VESA mount cover to remove it.
  6. HP EliteOne 800 G1 Power Supply Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the power supply's black and yellow cable from the motherboard.
  7. HP EliteOne 800 G1 Power Supply Replacement: Schritt 7, Bild 1 von 2 HP EliteOne 800 G1 Power Supply Replacement: Schritt 7, Bild 2 von 2
    • Use a Torx T15 driver to remove the two 8mm screws on either side of the power supply.
    • Lift the power supply from the case to remove it.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Michael Ewing
980 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 1-24, Maness Fall 2015 Mitglied von Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 18
Letzten 30 Tage: 53
Insgesamt: 4,307
