Zum Hauptinhalt wechseln
HP Elitebook 6930p CPU Replacement
Was du brauchst
  1. HP Elitebook 6930p CPU Replacement, Take off the Heatsink: Schritt 1, Bild 1 von 1
    • Unscrew the screws in order from left to right in the picture.
    • Insert wisdom here.
  2. HP Elitebook 6930p CPU Replacement, Unplug the fan: Schritt 3, Bild 1 von 1
    • Do this step if the cord of the fan is in the way of the CPU.
    • Make sure the new CPU works or is better than the old one if you are upgrading the CPU.
Abschluss
To reassemble your device, follow steps 1-4 in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Lowell
156 Reputation
2 Anleitungen geschrieben
Ein Kommentar
I have try to install both types T9900 and T9800 both CPU’s were not working at all. Bios F20 and operating System Win 7 32Bit.
it crashes already by try to access the bios
Maybe any sugestion about that?
moonlights - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 33
Insgesamt: 3,625
