Zum Hauptinhalt wechseln
HP Elitebook 6930p RAM (Expansion Slot) Replacement
Was du brauchst
  1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: Schritt 1, Bild 1 von 3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: Schritt 1, Bild 2 von 3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: Schritt 1, Bild 3 von 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): Schritt 2, Bild 1 von 2 HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): Schritt 2, Bild 2 von 2
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  3. HP Elitebook 6930p RAM (Expansion Slot) Replacement: Schritt 3, Bild 1 von 2 HP Elitebook 6930p RAM (Expansion Slot) Replacement: Schritt 3, Bild 2 von 2
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Richdave
32.150 Reputation
30 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.464 Anleitungen geschrieben
17 Kommentare
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Antwort
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Antwort
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - Antwort
Thank you for information.
By p8slot.com
sutep Fifa - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 48
Insgesamt: 15,547
