Zum Hauptinhalt wechseln
HP Elitebook 745 G6 Battery Replacement
Was du brauchst
  1. HP Elitebook 745 G6 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Elitebook 745 G6 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • To avoid data loss or damage to your laptop, discharge the battery below 25% and power off the device before beginning disassembly.
    • Hold the power button for 5 seconds until the laptop shuts down.
  2. HP Elitebook 745 G6 Battery Replacement: Schritt 2, Bild 1 von 2 HP Elitebook 745 G6 Battery Replacement: Schritt 2, Bild 2 von 2
    • Loosen all eight 4.5 mm captive Phillips #1 screws securing the lower case.
    • Do not attempt to fully remove the screws. They are intentionally held in to the back of the board with stoppers. This will not prevent you from opening the case.
  3. HP Elitebook 745 G6 Battery Replacement: Schritt 3, Bild 1 von 3 HP Elitebook 745 G6 Battery Replacement: Schritt 3, Bild 2 von 3 HP Elitebook 745 G6 Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert an opening pick into the seam between the lower case and chassis.
    • Run the opening pick along the entire perimeter of the device, prying every couple of centimeters, until the lower case fully releases.
    • Lift the lower case up and off.
  4. HP Elitebook 745 G6 Battery Replacement: Schritt 4, Bild 1 von 3 HP Elitebook 745 G6 Battery Replacement: Schritt 4, Bild 2 von 3 HP Elitebook 745 G6 Battery Replacement: Schritt 4, Bild 3 von 3
    • Use a T8 Torx screwdriver to remove the five 4 mm screws that secure the battery.
    • These screws are very small. Take care not to lose them.
  5. HP Elitebook 745 G6 Battery Replacement: Schritt 5, Bild 1 von 3 HP Elitebook 745 G6 Battery Replacement: Schritt 5, Bild 2 von 3 HP Elitebook 745 G6 Battery Replacement: Schritt 5, Bild 3 von 3
    • Pull the white battery connector directly out of its motherboard port.
    • Grab the connector by the two tabs, and not by the wires.
    • It does take quite a bit of force to disconnect the cable. Try wiggling it back and forth while you pull it out. Still, exercise caution to not damage your device.
    • You can also use opening picks to disconnect the battery if you have short fingernails.
    • Lift the battery up and out of the chassis.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.c
Sepehr Karahrodi
122 Reputation
1 Anleitung geschrieben
York University, Team 5-3, Woodhouse Winter 2025 Mitglied von York University, Team 5-3, Woodhouse Winter 2025
YORK-WOODHOUSE-W25S5G3
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 34
Insgesamt: 118
