Zum Hauptinhalt wechseln
HP Elitebook 820 G1 Fan Replacement
Was du brauchst
  1. HP Elitebook 820 G1 Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Fan Replacement: Schritt 3, Bild 1 von 1
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Fan Replacement: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Fan Replacement, Fan: Schritt 5, Bild 1 von 1
    • Remove the hard drive by unscrewing the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Fan Replacement: Schritt 6, Bild 1 von 1
    • Pry off ten rubber paddings on the outer edge of the laptop to reveal the torx screws.
    • Unscrew the ten 8mm torx screws that are under the rubber paddings using the T7 tip torx screwdriver.
  7. HP Elitebook 820 G1 Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 4mm screws indicated by the M2.5X4 using the J00 tip screwdriver.
    • Remove SD card cap by just sliding out to reveal one screw.
  8. HP Elitebook 820 G1 Fan Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 3mm screws indicated by the M2.03 using the J00 tip screwdriver.
    • Remove the 4mm SD card screw using the J00 tip.
  9. HP Elitebook 820 G1 Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove the one 4mm fan screw using the J00 tip screwdriver.
    • Remove screw and metal plate to expose ribbon cable connector.
  10. HP Elitebook 820 G1 Fan Replacement: Schritt 10, Bild 1 von 1
    • Use an opening tool to pry up the ribbon connector to disconnect.
  11. HP Elitebook 820 G1 Fan Replacement: Schritt 11, Bild 1 von 1
    • Turn laptop over back to normal position as shown in the image.
    • Use opening tools to pry up keyboard.
    • When prying up keyboard, be sure to start near any corner of the keyboard.
    • There are two ribbon cables that must be disconnected before fully removing keyboard.
  12. HP Elitebook 820 G1 Fan Replacement: Schritt 12, Bild 1 von 3 HP Elitebook 820 G1 Fan Replacement: Schritt 12, Bild 2 von 3 HP Elitebook 820 G1 Fan Replacement: Schritt 12, Bild 3 von 3
    • Carefully lift keyboard on one side to expose the two ribbon cables.
    • Use an opening tool to lift up the locking clip and unplug the two ribbon cables.
  13. HP Elitebook 820 G1 Fan Replacement: Schritt 13, Bild 1 von 1
    • Remove the two 4mm screws centered notated by the keyboard logo using the J00 tip.
  14. HP Elitebook 820 G1 Fan Replacement: Schritt 14, Bild 1 von 3 HP Elitebook 820 G1 Fan Replacement: Schritt 14, Bild 2 von 3 HP Elitebook 820 G1 Fan Replacement: Schritt 14, Bild 3 von 3
    • Once keyboard has been fully removed, the system case containing the motherboard can be lifted out easily.
    • The display is connected to the shell of the laptop.
  15. HP Elitebook 820 G1 Fan Replacement: Schritt 15, Bild 1 von 1
    • Unplug fan cable by pulling away from its connector.
  16. HP Elitebook 820 G1 Fan Replacement: Schritt 16, Bild 1 von 1
    • Unscrew the two 6mm fan screws using the J00 tip.
    • Fan screws are encased in springs and cannot be removed.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
[deleted]
217 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 76
Insgesamt: 8,558
