Einleitung
Hard drives are mechanical and begin to fail with age. Drops and physical damage can cause the drive to fail sooner. Follow this guide to the replace the hard drive. When replacing the hard drive, the Torx screws will be transferred to the new drive.
Was du brauchst
Remove the hard drive casing.
Unscrew the four 8mm Philips screws holding the hard drive.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
