Einleitung
The hard drive is the device that holds all of your saved data, such as your pictures, documents, etc. When your computer no longer boots up, the hard drive could be to blame. If the hard drive is the problem your having, this guide is will show you how to replace it.
Was du brauchst
The hard drive is found on the bottom right under the back panel.
Use a Phillips #0 screwdriver to unscrew the four 2 mm screws that secure the hard drive.
