Zum Hauptinhalt wechseln
Einleitung
The network card is the chip that allows you to connect to your home or local WiFi. If you are unable to connect, networks not showing up, then the network card could be causing the problem. If turning on your network capabilities under your computer settings doesn’t work, then this guide will show you how to replace a faulty network card.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Slide the lever firmly to the left on the back panel. Once the back panel is unlocked, there should be red showing to the right of the lever.
    • Slide the lever firmly to the left on the back panel.
    • Once the back panel is unlocked, there should be red showing to the right of the lever.
  2. Slide the back panel towards you. Lift the back panel to remove it.
    • Slide the back panel towards you.
    • Lift the back panel to remove it.
  3. Use a Phillips #0 screwdriver to remove the 2 mm head screw on the side of the network card. The card will pop up at an angle after the screw is removed like this.
    • Use a Phillips #0 screwdriver to remove the 2 mm head screw on the side of the network card.
    • The card will pop up at an angle after the screw is removed like this.
  4. After the screw is removed, the card can be wiggled back and forth while gently pulling backwards to take it out of its slot on the motherboard.
    • After the screw is removed, the card can be wiggled back and forth while gently pulling backwards to take it out of its slot on the motherboard.
    • Disconnect the two leads on the other screw side of the card. You have now removed the network card.
    • The leads and their connections on the card are labeled.
Abschluss
To reassemble your device, follow these instructions in reverse order. Note, when replacing the connections on the network card, they must be plugged in to the correct connections. Both the cables from the motherboard and connections on the network card are labeled.
2 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
My HP 820 G2’s WiFi/Bluetooth card was working bit intermittently. Especially Bluetooth was reconnecting all the time with my speakers if I didn’t listen to music.
I didn’t find any information which WiFi/Bluetooth card might be a good choice to upgrade. I took a chance and just ordered Intel 9260NGW card. It seems to work fine after couple hours; don’t know how it’ll be in the long run. My original card was Intel 7265NGW.
NGW = NGFF = M.2 slot, source: https://www.dell.com/community/Laptops-G...
Juho Itä - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 5
Letzten 30 Tage: 41
Insgesamt: 1,176
