Zum Hauptinhalt wechseln
HP Elitebook 830 G7 or G8 Top Cover replacement
Was du brauchst
  1. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove the Base Enclosure: Schritt 1, Bild 1 von 1
    • Flip the notebook.
    • Unscrew the screws.
    • Open the base enclosure using a plastic wedge (a credit card might also work). Follow the direction of the green arrows.
  2. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: Schritt 2, Bild 1 von 3 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: Schritt 2, Bild 2 von 3 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: Schritt 2, Bild 3 von 3
    • Detach the battery using a plastic spudger.
    • Unscrew the battery screws. Be aware not to damage the speaker cables.
    • Now remove the CMOS battery. Beware: it is glued to the enclosure. So remove with care.
    • Remove the SIM slot.
    • Now detach all connections with the mother board (using a plastic spudger). Unscrew the black (mostly flat) screws until the mother board is loose.
    • Put the Display Cables to the top side. In that way the cables aren't damaged when removing the top cover.
    • Remove the loose plastic parts on the motherboard.
  3. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove Top Cover: Schritt 3, Bild 1 von 2 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove Top Cover: Schritt 3, Bild 2 von 2
    • Detach the mother board.
    • Unscrew all the remaining components from the top cover.
    • Unscrew the black screws in the top corners until you can separate the top cover and the display.
  4. HP Elitebook 830 G7 or G8 Top Cover replacement, Re-assembly: Schritt 4, Bild 1 von 2 HP Elitebook 830 G7 or G8 Top Cover replacement, Re-assembly: Schritt 4, Bild 2 von 2
    • Attach the new Top Cover.
    • Follow the previous steps in reverse order.
    • Beware when closing the Base Enclosure: slide it towards the front at a 30 degree angle until it snaps in place. Screw everything back together. In this way you prevent an open gap at the front side.
Abschluss
To replace the top cover/keyboard, the device needs to be completely disassembled. That takes time but is not that difficult.
2 weitere Personen haben diese Anleitung absolviert.
nl en
100%
Marelec IT hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Angehängte Dokumente
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 91
Insgesamt: 5,020
