Zum Hauptinhalt wechseln
HP Elitebook 8460p Modem Card Replacement
Was du brauchst
  1. HP Elitebook 8460p Modem Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Modem Card Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Modem Card Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Modem Card Replacement: Schritt 4, Bild 1 von 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Modem Card Replacement, Modem Card: Schritt 5, Bild 1 von 2 HP Elitebook 8460p Modem Card Replacement, Modem Card: Schritt 5, Bild 2 von 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  6. HP Elitebook 8460p Modem Card Replacement: Schritt 6, Bild 1 von 2 HP Elitebook 8460p Modem Card Replacement: Schritt 6, Bild 2 von 2
    • Push down on one corner of the sound card and lift it straight up.
  7. HP Elitebook 8460p Modem Card Replacement: Schritt 7, Bild 1 von 2 HP Elitebook 8460p Modem Card Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 1,395
