Zum Hauptinhalt wechseln
HP Elitebook 8460p Optical Drive Replacement
Was du brauchst
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: Schritt 3, Bild 1 von 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: Schritt 5, Bild 1 von 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: Schritt 5, Bild 2 von 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: Schritt 5, Bild 3 von 3
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: Schritt 6, Bild 1 von 2 HP Elitebook 8460p Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: Schritt 7, Bild 1 von 3 HP Elitebook 8460p Optical Drive Replacement: Schritt 7, Bild 2 von 3 HP Elitebook 8460p Optical Drive Replacement: Schritt 7, Bild 3 von 3
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: Schritt 8, Bild 1 von 3 HP Elitebook 8460p Optical Drive Replacement: Schritt 8, Bild 2 von 3 HP Elitebook 8460p Optical Drive Replacement: Schritt 8, Bild 3 von 3
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 1,019
