Einleitung
Simple guide to replace your battery
Push the battery lock over so the red is showing Push the battery lock over so the red is showing
  • Push the battery lock over so the red is showing
Kommentar hinzufügen
Slide it towards you and then lift up, should come out fairly easy and then put the new one in and lock the switch
  • Slide it towards you and then lift up, should come out fairly easy and then put the new one in and lock the switch
Abschluss
10 weitere Nutzer haben diese Anleitung absolviert.
Joseph
Mitglied seit 16.07.2014
1.373 Reputation
6 Anleitungen geschrieben
I had no idea how to take the battery out of this laptop. So thank you so much for this! :-)
bluesapphire526 - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 134
Letzte 30 Tage: 542
Insgesamt: 28,028
