Zum Hauptinhalt wechseln
HP Elitebook Folio 9470m Keyboard Replacement
Was du brauchst
  1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
  3. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 3, Bild 1 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 3, Bild 2 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
  4. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 4, Bild 1 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 4, Bild 2 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
  5. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the 4 Phillips head keyboard screws.
    • The screws are also marked with small keyboard icons to distinguish them.
  6. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 6, Bild 1 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 6, Bild 2 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
    • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
    • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
  7. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 7, Bild 1 von 2 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 7, Bild 2 von 2
    • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Kenneth Bowers
1.432 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S1-G1, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G1
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 27
Letzte 30 Tage: 53
Insgesamt: 5,774
