Zum Hauptinhalt wechseln
HP Elitebook Folio 9470m Keyboard Replacement
Was du brauchst
  1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Flip laptop over.
  2. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
  3. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 3, Bild 1 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 3, Bild 2 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
  4. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 4, Bild 1 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 4, Bild 2 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
  5. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the 4 Phillips head keyboard screws.
    • The screws are also marked with small keyboard icons to distinguish them.
  6. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 6, Bild 1 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 6, Bild 2 von 3 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
    • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
    • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
  7. HP Elitebook Folio 9470m Keyboard Replacement: Schritt 7, Bild 1 von 2 HP Elitebook Folio 9470m Keyboard Replacement: Schritt 7, Bild 2 von 2
    • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kenneth Bowers
1.381 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S1-G1, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G1
4 Mitglieder
19 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 5,281
