Einleitung
A Wifi card allows you to connect to the Internet without a cable . If your HP Elitebook Folio 9470m Wifi card needs to be replaced, follow the instructions below.
Was du brauchst
Unscrew the 3 Phillips screws to remove the back plate by slightly lifting up and pulling out.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
