Zum Hauptinhalt wechseln
HP Envy 15-u001dx Cooling Fan Replacement
Was du brauchst
  1. HP Envy 15-u001dx Cooling Fan Replacement, HP Envy 15-u001dx Disassembly: Schritt 1, Bild 1 von 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Cooling Fan Replacement: Schritt 3, Bild 1 von 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Cooling Fan Replacement: Schritt 4, Bild 1 von 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Cooling Fan Replacement: Schritt 5, Bild 1 von 2 HP Envy 15-u001dx Cooling Fan Replacement: Schritt 5, Bild 2 von 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 1 von 2 HP Envy 15-u001dx Cooling Fan Replacement, Cooling Fan: Schritt 6, Bild 2 von 2
    • Remove the three 4.5 mm Phillips #0 screws holding the fan in place.
  7. HP Envy 15-u001dx Cooling Fan Replacement: Schritt 7, Bild 1 von 1
    • Gently detach the connector with a spudger and the fan is free to be removed.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 9-4, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,349
