Einleitung
The hard drive is responsible for storing all of the data on your laptop. Information from a defective hard drive can sometimes be recovered depending on the extent of the damage or problem.
Was du brauchst
Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
Remove the two cover tabs towards center of the bottom as there are screws underneath them.
Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
Separate the top cover by using a spudger to go around the sides freeing the inside latches.
2 weitere Personen haben diese Anleitung absolviert.
