Zum Hauptinhalt wechseln
HP Envy 15-u001dx Motherboard Replacement
Was du brauchst
  1. HP Envy 15-u001dx Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Flip the device over so the bottom is is facing up.
    • Peel up the two rubber feet closest to the hinge using the metal spudger to reveal two 6.6 mm Phillips #0 screws.
  2. HP Envy 15-u001dx Motherboard Replacement: Schritt 2, Bild 1 von 2 HP Envy 15-u001dx Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Peel up the small plastic coverings in the middle of the device with the spudger to reveal two more 6.6 mm Phillips #0 screws.
  3. HP Envy 15-u001dx Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Envy 15-u001dx Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove each of the fourteen 6.6 mm Phillips #0 screws with the Philips #0 screwdriver.
  4. HP Envy 15-u001dx Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Flip the device over and open it to reveal the keyboard.
    • Use the metal spudger to pry the chassis apart and reveal the inside of the device.
  5. HP Envy 15-u001dx Motherboard Replacement: Schritt 5, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 5, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the T/P cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  6. HP Envy 15-u001dx Motherboard Replacement: Schritt 6, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 6, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the keyboard cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  7. HP Envy 15-u001dx Motherboard Replacement: Schritt 7, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 7, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the battery cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  8. HP Envy 15-u001dx Motherboard Replacement: Schritt 8, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 8, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the AUX/USB cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  9. HP Envy 15-u001dx Motherboard Replacement: Schritt 9, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 9, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Disconnect the cable by flipping up the black plastic piece on the connector and pulling the cable out of the connector.
  10. HP Envy 15-u001dx Motherboard Replacement: Schritt 10, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 10, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 10, Bild 3 von 3
  11. HP Envy 15-u001dx Motherboard Replacement: Schritt 11, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 11, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 11, Bild 3 von 3
  12. HP Envy 15-u001dx Motherboard Replacement: Schritt 12, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 12, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Disconnect the cable by gently pulling it out. The spudger may be used to help loosen it.
  13. HP Envy 15-u001dx Motherboard Replacement: Schritt 13, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 13, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Remove the three 4.0 mm Phillips #0 screws with the Phillips #0 screwdriver on the fan.
    • Remove the fan by pulling it out of the chassis.
    • The connector tends to get stuck and forceful pulling will break it. Use the spudger to loosen the connector on each side.
  14. HP Envy 15-u001dx Motherboard Replacement: Schritt 14, Bild 1 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 14, Bild 2 von 3 HP Envy 15-u001dx Motherboard Replacement: Schritt 14, Bild 3 von 3
    • This connector may be hard to see because it is connected on the underside of the motherboard.
  15. HP Envy 15-u001dx Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Remove each of the six 4.0 mm screws with the Philips #0 screwdriver.
  16. HP Envy 15-u001dx Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Remove each of the three 4.0 mm screws around the fan with the Philips #0 screwdriver.
    • The fan will now be loose, and easy to lift out.
  17. HP Envy 15-u001dx Motherboard Replacement: Schritt 17, Bild 1 von 2 HP Envy 15-u001dx Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Gently pry the heat sink loose to release the motherboard.
  18. HP Envy 15-u001dx Motherboard Replacement: Schritt 18, Bild 1 von 2 HP Envy 15-u001dx Motherboard Replacement: Schritt 18, Bild 2 von 2
    • Disconnect the wifi card from the motherboard and remove the motherboard from the rest of the device.
  19. HP Envy 15-u001dx Motherboard Replacement: Schritt 19, Bild 1 von 1
    • The disconnected motherboard should look like the indicated photo.
Abschluss
Nathan Browning
373 Reputation
2 Anleitungen geschrieben
IUPUI, Team S1-G1, Henning Fall 2019 Mitglied von IUPUI, Team S1-G1, Henning Fall 2019
IUPUI-HENNING-F19S1G1
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 528
