Zum Hauptinhalt wechseln
HP Envy 15-u001dx Screen Replacement
Was du brauchst
  1. HP Envy 15-u001dx Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Remove the two screw covers located in the bottom corners of the screen and the 2.5 mm Phillips #0 screws underneath them.
    • If these screws are not removed and you separate the bottom portion of the screen, you will not be able to refasten the screen to the back because the screw tab will break.
  2. HP Envy 15-u001dx Screen Replacement: Schritt 2, Bild 1 von 2 HP Envy 15-u001dx Screen Replacement: Schritt 2, Bild 2 von 2
    • Only after removing the two bottom corner screws in Step 1, separate the screen from the back using an opening tool.
  3. HP Envy 15-u001dx Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 2.5 mm Phillips #0 screws with a Phillips#0 Screwdriver.
  4. HP Envy 15-u001dx Screen Replacement: Schritt 4, Bild 1 von 1
    • Detach the webcam from the damaged screen using spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. HP Envy 15-u001dx Screen Replacement: Schritt 5, Bild 1 von 1
    • Gently detach small white connector with spudger.
  6. HP Envy 15-u001dx Screen Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the tape with the wire to completely separate the screen.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 9-4, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 1,523
