Einleitung
The 15.6" screen shows you what the computer is actually doing. Computers still work without a screen, you just can't see what they are doing.
Was du brauchst
Remove the two screw covers located in the bottom corners of the screen and the 2.5 mm Phillips #0 screws underneath them.
Only after removing the two bottom corner screws in Step 1, separate the screen from the back using an opening tool.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
