Zum Hauptinhalt wechseln
HP Envy 17-3070NR Battery Replacement
Was du brauchst
  1. HP Envy 17-3070NR Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 HP Envy 17-3070NR Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Battery Replacement: Schritt 2, Bild 1 von 3 HP Envy 17-3070NR Battery Replacement: Schritt 2, Bild 2 von 3 HP Envy 17-3070NR Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Battery Replacement, Battery: Schritt 3, Bild 1 von 2 HP Envy 17-3070NR Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
  4. HP Envy 17-3070NR Battery Replacement: Schritt 4, Bild 1 von 3 HP Envy 17-3070NR Battery Replacement: Schritt 4, Bild 2 von 3 HP Envy 17-3070NR Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
    • Remove the battery by pulling it straight out away from the computer.
    • It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Abby Lentz
586 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-8, Amido Spring 2015 Mitglied von Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 8,863
