Zum Hauptinhalt wechseln
HP Envy 17-3070NR Optical Drive Replacement
Was du brauchst
  1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: Schritt 1, Bild 1 von 2 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Optical Drive Replacement: Schritt 2, Bild 1 von 3 HP Envy 17-3070NR Optical Drive Replacement: Schritt 2, Bild 2 von 3 HP Envy 17-3070NR Optical Drive Replacement: Schritt 2, Bild 3 von 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: Schritt 3, Bild 2 von 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: Schritt 3, Bild 3 von 3
    • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
    • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
    • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
    • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
  4. HP Envy 17-3070NR Optical Drive Replacement: Schritt 5, Bild 1 von 3 HP Envy 17-3070NR Optical Drive Replacement: Schritt 5, Bild 2 von 3 HP Envy 17-3070NR Optical Drive Replacement: Schritt 5, Bild 3 von 3
    • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Abschluss
Jon Fuson
140 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-8, Amido Spring 2015 Mitglied von Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,201
