Was du brauchst
Slide the release latch away from the nearest edge.
Slide the back cover off of the computer.
Remove the six 3.7mm Phillips screws.
Slide the back cover until it clicks, then lift it straight off.
Remove the four 3.7mm Phillips screws that hold the hard drive onto the computer.
Remove the hard drive by lifting it out of its cavity.
Unplug the hard drive cable that connects it to the main assembly.
Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
Remove the battery by pulling it straight out away from the computer.
Unscrew the three 6.5mm Phillips shoulder screws that connect the subwoofer to the computer.
Disconnect the red and black subwoofer cable from the system board by pulling it upwards.
Remove the subwoofer by pulling straight up from the main assembly.
Remove the first connector by lifting the white clamp with a Flathead screwdriver and pulling the connector to your right.
Remove the seventeen 6.6mm Phillips screws.
Remove the three 3.6 mm Phillips screws.
Remove the eleven 3.2mm Phillips screws
Flip the laptop over.
Use a Plastic Opening tool to carefully pry all around the top cover up off of the remaining assembly.
Gently pull the white connector shown in the picture towards you to disconnect it from the system board.
Gently pull the black connector towards you to disconnect the top cover from the main assembly.
Once both connectors are disconnected, lift the top cover off of the main assembly.
