Zum Hauptinhalt wechseln
HP Envy 17-3070NR Wireless Card Replacement
Was du brauchst
  1. HP Envy 17-3070NR Wireless Card Replacement, Back Cover: Schritt 1, Bild 1 von 2 HP Envy 17-3070NR Wireless Card Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Before you begin taking apart the computer, make sure that it is completely powered off.
    • Slide the release latch away from the nearest edge.
    • Slide the back cover off of the computer.
  2. HP Envy 17-3070NR Wireless Card Replacement: Schritt 2, Bild 1 von 3 HP Envy 17-3070NR Wireless Card Replacement: Schritt 2, Bild 2 von 3 HP Envy 17-3070NR Wireless Card Replacement: Schritt 2, Bild 3 von 3
    • Remove the six 3.7mm Phillips screws.
    • Slide the back cover until it clicks, then lift it straight off.
  3. HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: Schritt 3, Bild 1 von 3 HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: Schritt 3, Bild 2 von 3 HP Envy 17-3070NR Wireless Card Replacement, Wireless Card: Schritt 3, Bild 3 von 3
    • Unscrew 4.5mm Phillips screw.
    • Unplug both antenna connectors by carefully pulling them upwards.
    • During re-assembly make sure to match numbers(1 or 2) on the antenna cable and the wireless card.
  4. HP Envy 17-3070NR Wireless Card Replacement: Schritt 4, Bild 1 von 3 HP Envy 17-3070NR Wireless Card Replacement: Schritt 4, Bild 2 von 3 HP Envy 17-3070NR Wireless Card Replacement: Schritt 4, Bild 3 von 3
    • Pull wireless card up and away from you.
Abschluss
Jasper Lewin
750 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-8, Amido Spring 2015 Mitglied von Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,087
