Einleitung
If your laptop battery does not stay charged for very long, or you suspect it has sustained damage, it is time to replace it. This guide will instruct you how to replace the battery in the HP Envy 17-J013CL. The battery is what supplies power to the device, allowing it to be used for several hours without a power cord. Before beginning, be sure to turn your laptop off, and disconnect the AC cable and other power sources from the device before removing the battery. There are no tools required for this replacement.
Was du brauchst
Grab hold of the small battery slider and apply pressure to the right.
The laptop itself will push the battery out for you once the switch slides all the way to the right.
To reassemble your device, line up the battery and place it down into the metallic prongs for a stable connection.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
where does one buy a replacement battery for this HP envy17?
