Einleitung
This step-by-step guide will help you on your journey disassembling the Fan Module.
Was du brauchst
Hold the laptop and push the slider all the way till the battery pops out a little.
Lift the back plate off the laptop, make sure to remove any wires connected to it.
To reassemble your device, follow these instructions in reverse order. (Don’t forget to plug in each wire)
Eine weitere Person hat diese Anleitung absolviert.
