Einleitung
Use this guide if you want to replace the motherboard of your HP Envy 17-J013CL. The motherboard is the guts of the computer where all the internal parts connect together to make the whole thing work. Without it there is no way for signals and information to pass along one another. There are a lot of pins, sockets, and ports so it is important to stay grounded and be gentle with it. Bending it can also break it!
Was du brauchst
Grab hold of the small battery slider and apply pressure to the right.
The laptop itself will push the battery out for you once the switch slides all the way to the right.
Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
Gently pull the back panel off starting from the battery side towards the back.
Pull it back as it snaps out of the holding sockets.
Locate the 7mm screw for the optical drive right next to the WLAN and Memory modules.
Remove the screw with a PH1-screwdriver to release the CD-drive.
Use a PH1-Screwdriver to remove all the 7mm screws.
Use a PH0-Screwdriver to remove the 3mm screws.
Use the same PH0-Screwdriver for the 2mm screws.
Pull the under panel from the laptop by pulling at the edges once all screws are removed. Gently lift it off and place to the side.
Unscrew the coiled springs indicated in red from the the motherboard.
Remove the 7mm screws with a PH1-screwdriver to loosen the fan.
Unplug the fan from the motherboard.
Use a Flathead screwdriver to turn the screw 180 degrees to unlock the processor from the motherboard.
Gently and vertically lift the processor out.
Locate the two bottom cables and lift up the black secure tabs.
Grab the cables by the translucent tabs and gently pull them out of the motherboard.
On the left side of the motherboard, remove the two cables by first lifting the black secure tabs and using the translucent tabs to pull them out.
Next to the WLAN, remove the two plugs indicated in red from the motherboard.
Remove the flat cable from the motherboard by first lifting the securing black tab and pulling it out.
Where the CPU fan was, lift the securing tabs on the cables and extract them from the motherboard.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
What is the proper name of the housing that the motherboard sets in? I need to order one of these because all the hinge plastic is broken.
TIA
Jim
