Zum Hauptinhalt wechseln
HP Envy 17m-ae111dx CPU Fan Replacement
Was du brauchst
  1. HP Envy 17m-ae111dx CPU Fan Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop on its back.
  2. HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 2, Bild 1 von 3 HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 2, Bild 2 von 3 HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 2, Bild 3 von 3
    • Remove the plastic covering to the Disk Reader.
    • Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
    • If the button on the side is jammed, pry off the covering by using the iFixit Opening Tool.
  3. HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 3, Bild 1 von 3 HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 3, Bild 2 von 3 HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 3, Bild 3 von 3
    • Unscrew all visible screws.
    • Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
    • One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
  4. HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 4, Bild 1 von 2 HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 4, Bild 2 von 2
    • Pry the gripper completely off to expose the two screws.
    • Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
  5. HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 5, Bild 1 von 3 HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 5, Bild 2 von 3 HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 5, Bild 3 von 3
    • Use the iFixit opening tool to pry off the back cover.
    • Ensure that you go all the way around the laptop with the tool to take it off.
  6. HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: Schritt 6, Bild 1 von 3 HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: Schritt 6, Bild 2 von 3 HP Envy 17m-ae111dx CPU Fan Replacement, CPU Fan: Schritt 6, Bild 3 von 3
    • Use the Phillips #00 screwdriver to remove the three 5.5mm screws that secure the fan.
    • Unplug the wire that is connected to the fan and move the wires so they are out of the way of the fan.
    • Remove the tape off of the fan that is holding the wires in place against the fan.
  7. HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 7, Bild 1 von 2 HP Envy 17m-ae111dx CPU Fan Replacement: Schritt 7, Bild 2 von 2
    • Remove the fan from the laptop, ensuring the wires are properly disconnected.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Excellent video...extremely helpful...thank you
Frank D - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 1,996
