Zum Hauptinhalt wechseln
Einleitung
My computer doesn't have enough room anymore for the music and photos that I want to store! I don't want to say good-bye to any files. What can I do so that I am able to store more files on my computer? Replacing the hard drive won't be too hard!
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use your hands to unclip the plastic snaps on the back panel of the device.
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. Remove the three 11.5mm PH2 screws from the back panel.
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. Now, take the back panel off by pulling at it gently with your hands.
    • Now, take the back panel off by pulling at it gently with your hands.
  4. Remove the one 13.5mm PH2 screw.
    • Remove the one 13.5mm PH2 screw.
  5. Unsnap the wire mechanism to release the hard drive.
    • Unsnap the wire mechanism to release the hard drive.
  6. Detach the hard drive assembly by pulling it out of the socket. Detach the hard drive assembly by pulling it out of the socket.
    • Detach the hard drive assembly by pulling it out of the socket.
  7. Remove the two 8.5mm PH2 screws on each side of the hard drive cover.
    • Remove the two 8.5mm PH2 screws on each side of the hard drive cover.
  8. Detach the hard drive cover by sliding it off from the rest of the hard drive
    • Detach the hard drive cover by sliding it off from the rest of the hard drive
    • Replace the old hard drive with your new hard drive.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Zachary Dicks
1.056 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 5-10, Maness Fall 2015 Mitglied von Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Mitglieder
14 Anleitungen geschrieben
Thank you so much my hard drive is bad this is going to be a quick fix and save me money you made this for dummies I LOVE IT can u tell me when I replace the hard drive will I lose everything on my computer already such as photos,files, I have everything in office purchased on the computer ? If so is there a way not to lose anything
jessica Kramer - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 7
Letzten 30 Tage: 30
Insgesamt: 5,414
