Zum Hauptinhalt wechseln
HP Envy 4-1030us Battery Replacement
Was du brauchst
  1. HP Envy 4-1030us Battery Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 HP Envy 4-1030us Battery Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us Battery Replacement: Schritt 2, Bild 1 von 2 HP Envy 4-1030us Battery Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us Battery Replacement, Battery: Schritt 3, Bild 1 von 2 HP Envy 4-1030us Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Disconnect the battery cable from the motherboard. This will be found above the battery and below the CPU fan.
    • To take the cable out, carefully grab the head of the cable and slowly pull it outwards.
  4. HP Envy 4-1030us Battery Replacement: Schritt 4, Bild 1 von 2 HP Envy 4-1030us Battery Replacement: Schritt 4, Bild 2 von 2
    • Use the Philips #0 screwdriver to remove the three 4.2mm screws that are securing the battery to the board.
  5. HP Envy 4-1030us Battery Replacement: Schritt 5, Bild 1 von 2 HP Envy 4-1030us Battery Replacement: Schritt 5, Bild 2 von 2
    • Then slowly remove the battery from the right side of the battery and then raise it up.
    • Make sure to move the USB Audio board cable away from the battery incase it gets caught.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G1, Thompson Fall 2017 Mitglied von USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 949
