Zum Hauptinhalt wechseln
HP Envy 4-1105dx Hard Drive Replacement
Was du brauchst
  1. HP Envy 4-1105dx  Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off the device before beginning disassembly. Disconnect all external devices.
    • Flip the device on its back.
  2. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
  3. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
  4. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
  5. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Once the device is open, move the ribbon cable to the side.
  6. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
  7. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
  8. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Lift the battery up and remove.
    • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
  9. HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: Schritt 9, Bild 1 von 2 HP Envy 4-1105dx  Hard Drive Replacement, Hard Drive: Schritt 9, Bild 2 von 2
    • Remove the four 4.0 mm screws that hold down the hard drive case using a Philips #1 Screwdriver.
    • Move the hard drive case and hard drive so that you can easily reach the hard drive cable.
  10. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 10, Bild 1 von 3 HP Envy 4-1105dx  Hard Drive Replacement: Schritt 10, Bild 2 von 3 HP Envy 4-1105dx  Hard Drive Replacement: Schritt 10, Bild 3 von 3
    • Use the plastic spudger tool to loosen the hard drive SATA cable connection by pushing it away from the motherboard.
    • Once it is loose, pull the hard drive out of the socket.
    • Remove the hard drive from the device.
  11. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 11, Bild 1 von 3 HP Envy 4-1105dx  Hard Drive Replacement: Schritt 11, Bild 2 von 3 HP Envy 4-1105dx  Hard Drive Replacement: Schritt 11, Bild 3 von 3
    • Pull out the hard drive cable from the hard drive, and set it aside.
    • Remove the four 3.0 mm screws that attach the hard drive case to the hard drive using a Philips #1 Screwdriver. If the screwdriver is too big, try #0 sized screwdriver.
  12. HP Envy 4-1105dx  Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • Remove the hard drive from the hard drive case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 874
