Einleitung
Use this guide to give a new lease on life to your HP device by replacing the battery. If the battery does not charge past a low level or shuts down unexpectedly, it may be time to replace it. This guide provides detailed instructions for removing the battery from your device.
Was du brauchst
Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
