Einleitung
This guide will show you how to replace the glass scanner bed.
Was du brauchst
Remove the large flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
Remove the small flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
Remove the clip holding the scanner bed up by using the plastic opening tools. Prying the clip away from the the side of the scanner bed.
Using the plastic opening tools, pry between the outer shell and the main plastic frame.
Remove the black flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling it away from the port.
Lift the scanner bed in an upward motion out of the printer.
Remove the nine 14 mm T10 Hex screws located around the edge of the scanner bed (Bottom).
Pry the two plastic flanges outward to release the glass scanner bed.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
step 4 - Remove the clip holding the scanner bed up by using the plastic opening tools. Prying the clip away from the the side of the scanner bed.
That clip is designed to be pulled toward the front of the printer to be released from the pin. And push the arm toward the back to snap back in place.
