Einleitung
The replacement of LCD screen will require a T10 and a T6 screwdriver.
Was du brauchst
Remove the large flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
Remove the small flat ribbon cable by pinching the top and bottom of the cable between thumb and index finger and pulling away from the mother board.
Remove the four T6, 7 mm mounting screws.
Remove the LCD screen out of the plastic housing.
Eine weitere Person hat diese Anleitung absolviert.
