Einleitung
The LCD screen of the HP Envy 5660 tells the user about the status of the printing. It also informs the user about the ink levels and provides different functions, such as copying and faxing documents. There may be a chance that the LCD doesn't work anymore and this guide will help the user replace it.
  1. Lift the scanner to open up the printer cartridge access area.
    • Lift the scanner to open up the printer cartridge access area.
  2. Remove the two 12 mm screws with a T10 bit. Remove the two 12 mm screws with a T10 bit.
    • Remove the two 12 mm screws with a T10 bit.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Use a metal spudger to pry open the front panel. Work your way all the way around the front panel doing the same. Gently flip the cover over, exposing the motherboard.
    • Use a metal spudger to pry open the front panel.
    • Work your way all the way around the front panel doing the same.
    • Gently flip the cover over, exposing the motherboard.
    • There will be loud popping sounds when the cover is being separated from the rest of the printer.
  5. Remove the four 4.5 mm screws from the motherboard with a T6 bit. Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Remove the four 4.5 mm screws from the motherboard with a T6 bit.
    • Gently remove the motherboard from the top of the LCD, but make sure the ribbon cables are still attached.
    • Beware damaging the white ribbon cable.
  6. Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover, Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
    • Remove the four 5 mm screws with a T6 bit, allowing you to separate the LCD from the cover,
  7. Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
    • Place the metal spudger underneath the LCD and gently lift up to remove the LCD.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ryan Steakley
766 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G6, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Mitglieder
Great description but there is a part needed - the LCD. Is that part available? How do I get it?
Thanks,
PJE
pateckelberry - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 24
Insgesamt: 247
