Einleitung
The print head of the HP Envy 5660 is the piece that puts the ink onto the paper inserted into the printer. This guide will go over the replacement of the print head.
Was du brauchst
Unscrew the black 11.5 mm screw closest to the front right corner using a T10 screw bit.
Remove right side of the printer using a plastic opening tool or metal spudger.
Push the metal rail the print head rests on inwards to remove it from its bearings.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
