Zum Hauptinhalt wechseln
HP Envy 5660 Scanner Piece Replacement
Was du brauchst
  1. HP Envy 5660 Scanner Piece Replacement, Scanner Glass: Schritt 1, Bild 1 von 1
    • Open the cartridge access area.
  2. HP Envy 5660 Scanner Piece Replacement: Schritt 2, Bild 1 von 1
    • Remove the three 11.5 mm screws with a T10 bit.
  3. HP Envy 5660 Scanner Piece Replacement: Schritt 3, Bild 1 von 3 HP Envy 5660 Scanner Piece Replacement: Schritt 3, Bild 2 von 3 HP Envy 5660 Scanner Piece Replacement: Schritt 3, Bild 3 von 3
    • Locate the cover hinge on the right side of the printer.
    • Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
  4. HP Envy 5660 Scanner Piece Replacement: Schritt 4, Bild 1 von 2 HP Envy 5660 Scanner Piece Replacement: Schritt 4, Bild 2 von 2
    • Remove the 12 mm screws on the left side of the printer with a T10 bit.
  5. HP Envy 5660 Scanner Piece Replacement: Schritt 5, Bild 1 von 2 HP Envy 5660 Scanner Piece Replacement: Schritt 5, Bild 2 von 2
    • Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
    • Since this is a compression spring, the hinge will snap downwards as soon as it is loosened.
  6. HP Envy 5660 Scanner Piece Replacement: Schritt 6, Bild 1 von 3 HP Envy 5660 Scanner Piece Replacement: Schritt 6, Bild 2 von 3 HP Envy 5660 Scanner Piece Replacement: Schritt 6, Bild 3 von 3
    • Pull the plastic side cover off of the printer.
    • You may need to lift the printer and push the cover downwards as it is latched onto the bottom of the printer.
    • Plastic opening tools or a metal spudger may also be used.
  7. HP Envy 5660 Scanner Piece Replacement: Schritt 7, Bild 1 von 1
    • Remove the five 11.5 mm screws located at the bottom of the scanner.
    • Steps 3-6 were intended to create easier access to these screws. However, they will still be difficult to reach.
    • The top of the scanner will now easily pull off.
  8. HP Envy 5660 Scanner Piece Replacement: Schritt 8, Bild 1 von 2 HP Envy 5660 Scanner Piece Replacement: Schritt 8, Bild 2 von 2
    • Pry the old scanning glass up with a metal spudger.
    • There are adhesives under the scanning glass. Be careful not to break the glass while removing it.
  9. HP Envy 5660 Scanner Piece Replacement, Scanner Piece: Schritt 9, Bild 1 von 3 HP Envy 5660 Scanner Piece Replacement, Scanner Piece: Schritt 9, Bild 2 von 3 HP Envy 5660 Scanner Piece Replacement, Scanner Piece: Schritt 9, Bild 3 von 3
    • The scanning piece is located in the bottom half of the scanner that was not separated from the printer.
    • Lift the scanning piece and detach the ribbon cable by gently pulling on it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Steakley
781 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G6, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 911
