Einleitung
This guide will show you the process of replacing the CPU fan on the HP Envy 700-030qe desktop computer.
Was du brauchst
Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
Unscrew the 10.5mm screw on the left of the desktop using your hand.
Next, remove the side panel by sliding it towards the back of the desktop and pulling up, as shown.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Fails to mention the most important part of the entire procedure. That would be to remove the old thermal paste from the top of the CPU with 91-99% isopropyl alcohol and re-apply new thermal paste. Short of doing this almost guarantees failure to maintain proper cooling.
