Zum Hauptinhalt wechseln
HP Envy 700-030qe CPU Fan Replacement
Was du brauchst
  1. HP Envy 700-030qe CPU Fan Replacement, CPU Fan: Schritt 1, Bild 1 von 3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: Schritt 1, Bild 2 von 3 HP Envy 700-030qe CPU Fan Replacement, CPU Fan: Schritt 1, Bild 3 von 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe CPU Fan Replacement: Schritt 2, Bild 1 von 2 HP Envy 700-030qe CPU Fan Replacement: Schritt 2, Bild 2 von 2
    • Next, remove the side panel by sliding it towards the back of the desktop and pulling up, as shown.
  3. HP Envy 700-030qe CPU Fan Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 120mm Phillips #000 head, 5 mm screws holding the fan.
  4. HP Envy 700-030qe CPU Fan Replacement: Schritt 4, Bild 1 von 1
    • Carefully pull up and disconnect the fan's power cable.
  5. HP Envy 700-030qe CPU Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the fan by pulling up carefully.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 5-9, Maness Fall 2015 Mitglied von Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
Im looking to replace the fan in mine, what size would I look for, or even what model would be best?
AzyP Zero - Antwort
Did you ever determine what fan to use ? I need to order one for my system.
Dennis - Antwort
I bought the Philips #000 Screwdriver from iFixit as listed above. It is not even close to what is needed. That screwdriver is like a jewelers tiny Philips head. It needs a much bigger screwdriver.
Dennis - Antwort
Fails to mention the most important part of the entire procedure. That would be to remove the old thermal paste from the top of the CPU with 91-99% isopropyl alcohol and re-apply new thermal paste. Short of doing this almost guarantees failure to maintain proper cooling.
Guy Martin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 34
Insgesamt: 3,373
