Zum Hauptinhalt wechseln
HP Envy 700-030qe Power Supply Replacement
Was du brauchst
  1. HP Envy 700-030qe Power Supply Replacement, Power Supply: Schritt 1, Bild 1 von 3 HP Envy 700-030qe Power Supply Replacement, Power Supply: Schritt 1, Bild 2 von 3 HP Envy 700-030qe Power Supply Replacement, Power Supply: Schritt 1, Bild 3 von 3
    • Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
    • Unscrew the 10.5mm screw on the left of the desktop using your hand.
    • If it is too tight you may use a torx-head screwdriver or a flat-head screwdriver.
  2. HP Envy 700-030qe Power Supply Replacement: Schritt 2, Bild 1 von 2 HP Envy 700-030qe Power Supply Replacement: Schritt 2, Bild 2 von 2
    • Remove the side panel by sliding it towards the back of the desktop and pulling up on it as shown.
  3. HP Envy 700-030qe Power Supply Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 5mm screws holding the power supply in place with a T15 Torx screwdriver.
  4. HP Envy 700-030qe Power Supply Replacement: Schritt 4, Bild 1 von 2 HP Envy 700-030qe Power Supply Replacement: Schritt 4, Bild 2 von 2
    • Undo the clasp which holds the power supply in place by pushing down on it.
    • Pull out the power supply up and towards you.
  5. HP Envy 700-030qe Power Supply Replacement: Schritt 5, Bild 1 von 1
    • Unplug the power cable going to the CD drive by pulling straight.
  6. HP Envy 700-030qe Power Supply Replacement: Schritt 6, Bild 1 von 1
    • Set aside the power supply on the left side of the computer.
  7. HP Envy 700-030qe Power Supply Replacement: Schritt 7, Bild 1 von 1
    • Unplug the SATA interface power cable going to the hard drive by pulling straight up.
  8. HP Envy 700-030qe Power Supply Replacement: Schritt 8, Bild 1 von 1
    • Unplug the power cable going to the mother board by pulling straight up.
  9. HP Envy 700-030qe Power Supply Replacement: Schritt 9, Bild 1 von 1
    • Unplug the power cable going to the fan by pulling straight up.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Yoav Rosenberg
369 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-9, Maness Fall 2015 Mitglied von Cal Poly, Team 5-9, Maness Fall 2015
CPSU-MANESS-F15S5G9
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 4,511
