Einleitung
In this guide, we will show you the proper way to remove your RAM chips from your computer.
Was du brauchst
Make sure that you are wearing your anti-static wristband. This will prevent damaging any internal parts with any built up static electricity.
Unscrew the 10.5mm screw on the left of the desktop using your hand.
You can now slide off the side panel of the desktop.
You should now have an opening on the side of your computer as shown in the second picture.
Undo the clips on each end of the chip as shown in the second picture.
Then you may carefully remove the RAM chips by pulling them out by their the ends.
