Zum Hauptinhalt wechseln
HP Envy 7640 Screen Replacement
Was du brauchst
  1. HP Envy 7640 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 HP Envy 7640 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 HP Envy 7640 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Open the printer by pushing upwards against the plastic tabs on the printer body's sides.
    • Remove the opening assist by pushing it toward the front of the printer with a nylon spudger.
    • Remove the spring-loaded clip attached to the top of the printer by pushing it off of the hook.
  2. HP Envy 7640 Screen Replacement: Schritt 2, Bild 1 von 3 HP Envy 7640 Screen Replacement: Schritt 2, Bild 2 von 3 HP Envy 7640 Screen Replacement: Schritt 2, Bild 3 von 3
    • Place the T9 Torx screwdriver in the screw slot and turn counterclockwise to remove the two 12 mm screws that hold the screen manifold to the printer.
    • Push with minimal force to the right to dislodge the manifold from the printer body.
    • Lift the panel up and turn it over to reveal the green micro-controller board underneath.
  3. HP Envy 7640 Screen Replacement: Schritt 3, Bild 1 von 2 HP Envy 7640 Screen Replacement: Schritt 3, Bild 2 von 2
    • Undo the two connectors by gently pulling them away from the board.
    • Remove the last connector by flipping the tab up and pulling away from the board while also pulling left.
    • Remove the five 6.5 mm screws from the board using the T6 Torx screwdriver.
  4. HP Envy 7640 Screen Replacement: Schritt 4, Bild 1 von 1
    • Insert the plastic opening tool into the space between the green board and the printer manifold and push downwards to dislodge the green board.
  5. HP Envy 7640 Screen Replacement: Schritt 5, Bild 1 von 3 HP Envy 7640 Screen Replacement: Schritt 5, Bild 2 von 3 HP Envy 7640 Screen Replacement: Schritt 5, Bild 3 von 3
    • Peel back the tape that holds the screen in place.
    • Insert the plastic opening tool between the white screen backing and the screen to pry the screen backing from the adhesive that holds it in place.
Abschluss
Cal Poly, Team S1-G2, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G2
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 889
