Einleitung
Has your battery seemingly died far earlier than expected in your HP Envy 15 x360 laptop? This guide will show you how to fix a common cause of a dead battery.
Was du brauchst
Plug in your computer to charge and take a look at the light coming from near the charging port.
Flip the laptop over on its back and remove the two depressed stickers in the middle to reveal the two central 6.0 mm Phillips-head screws.
Once all of the screws have come out, flip the laptop over and open the lid so that the keyboard is face up.
Pop the keyboard from the sides and carefully lift it off of the parts underneath.
Carefully lay the keyboard section against the open screen of your laptop without unplugging anything.
Check the inside of your laptop to make sure there are no glaringly obvious problems (insects, missing parts, scorched parts).
Locate the battery and the three 4.0 mm Phillips-head screws that hold it in place.
Unscrew these three screws and use the tab attached to the battery to remove it safely from the laptop.
Once the battery is safely removed, plug the charging cord into the charging port on the side and plug the other end into the wall.
If the light is on after plugging it in, you have just confirmed that something is wrong with the battery, which means you're on the right track!
Unplug the charging cable.
Place the battery back where it was previously and find where it was plugged in.
Plug the cable on the battery back into the port on the motherboard and make sure it is secured.
Run the earlier test from Step 7 that you performed on the laptop with the battery inside.
If the light comes on and doesn't blink, you have fixed the problem! Congratulations!
If the light still blinks, you may have to purchase a new battery for your laptop.
20 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
can you tell me the name of the battery ?
Worked like a gem. Now my battery is even charging. There must be a loose connection between the battery and mother board. Double thumbs up to you!
This worked like a charm for me. Thank you for posting!! followed directions exactly, so easy to follow. The only trouble I had was getting the keyboard detached. It was really stuck on there, but I eventually got it. Battery is charging as we speak.
