Zum Hauptinhalt wechseln
HP Envy M6-1205DX Palm Rest Replacement
Was du brauchst
  1. HP Envy M6-1205DX Palm Rest Replacement, Battery: Schritt 1, Bild 1 von 1
    • Lay the device face down to begin.
  2. HP Envy M6-1205DX Palm Rest Replacement: Schritt 2, Bild 1 von 1
    • Slide the release mechanism to the left to release the battery.
  3. HP Envy M6-1205DX Palm Rest Replacement: Schritt 3, Bild 1 von 2 HP Envy M6-1205DX Palm Rest Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery.
  4. HP Envy M6-1205DX Palm Rest Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the 8.6 mm screw.
  5. HP Envy M6-1205DX Palm Rest Replacement: Schritt 5, Bild 1 von 1
    • Slide the center panel down to remove it.
  6. HP Envy M6-1205DX Palm Rest Replacement, Palm Rest: Schritt 6, Bild 1 von 1
    • Set the computer facing upwards again.
    • Using the plastic opening tool gently pry the keyboard up.
  7. HP Envy M6-1205DX Palm Rest Replacement: Schritt 7, Bild 1 von 3 HP Envy M6-1205DX Palm Rest Replacement: Schritt 7, Bild 2 von 3 HP Envy M6-1205DX Palm Rest Replacement: Schritt 7, Bild 3 von 3
    • Flip the white tab on the large ribbon cable upward. Gently pull the large ribbon cable out to remove it.
    • Gently pull the small ribbon cable out to remove it.
  8. HP Envy M6-1205DX Palm Rest Replacement: Schritt 8, Bild 1 von 3 HP Envy M6-1205DX Palm Rest Replacement: Schritt 8, Bild 2 von 3 HP Envy M6-1205DX Palm Rest Replacement: Schritt 8, Bild 3 von 3
    • Gently pull the tension cable to remove it.
  9. HP Envy M6-1205DX Palm Rest Replacement: Schritt 9, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the four 5.6 mm silver screws.
  10. HP Envy M6-1205DX Palm Rest Replacement: Schritt 10, Bild 1 von 2 HP Envy M6-1205DX Palm Rest Replacement: Schritt 10, Bild 2 von 2
    • Use the plastic opening tool to loosen the palm rest from the frame.
    • Once you pry all of the snaps up lift off the palm rest.
Abschluss
Ryan Hatton
634 Reputation
5 Anleitungen geschrieben
IUPUI, Team S2-G2, Wilson Fall 2019 Mitglied von IUPUI, Team S2-G2, Wilson Fall 2019
IUPUI-WILSON-F19S2G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 295
