Einleitung
We will be showing you how to replace your screen if it is broken or damaged. This is a fairly long process which requires you to be careful.
Was du brauchst
Using a Phillips #1, remove the 8 10.6mm screws.
Also using a Phillips #1, remove the 8.6mm screw.
Using a Phillips #1, remove the 3.5mm screw.
Using a Phillips #1, remove the four 10.6mm screws.
Flip the black tab up on the clamp that holds the ribbon cable in place.
Pull the cable back with your fingers or a pair of tweezers.
Flip the computer back over
Use the plastic opening tool to pry the keyboard up .
Carefully lift the keyboard up.
Flip up the black tab holding the large ribbon cable down.
Push both sides of the small white tab forward to release the small ribbon cable.
Pull both the cables out to remove them.
Remove the keyboard.
Flip the small white tab up to release the ribbon cable.
Pull to remove.
Repeat the same steps for the other cable.
Use the plastic opening tool to pry the face plate off the rest of the frame.
Once you pry all of the snaps up lift the face plate off.
Using a Phillps #1, remove the two 5.6mm silver screws from the base of the first hinge.
Also using a Phillips #1, remove the two 5.6mm silver screws from the base of the second hinge.
Using a plastic opening tool, carefully start prying the frame of the screen up
Remove the three 1.9mm silver screws from the base of the screen frame using the Phillips 00 screwdriver.
Carefully pry the edge of the frame up to expose the other half of the first hinge.
Using a Phillips #1, remove the three 2.8mm silver screws.
Pull the hinge out.
Care full pry up the other corner of the frame
Pull the hinge out.
Using a Phillips #00, remove the four 2.3 mm black screws.
Lift the screen and frame out of the computer body.
Flip the screen over
There is a black cable that is connected to the screen through the frame.
Pull back the tape that holds the cable in
Pull the cable out to remove it.
5 weitere Personen haben diese Anleitung absolviert.
