Zum Hauptinhalt wechseln
HP Envy Sleekbook m6-k010dx LCD Replacement
Was du brauchst
  1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 2, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 4, Bild 1 von 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 5, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: Schritt 6, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: Schritt 6, Bild 2 von 2
    • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
  7. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
  8. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 8, Bild 1 von 3 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 8, Bild 2 von 3 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 8, Bild 3 von 3
    • Use the plastic opening tool to pry the bezel free from the LCD housing.
  9. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 9, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 9, Bild 2 von 2
    • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
  10. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 10, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 10, Bild 2 von 2
    • Use the plastic opening tool to remove the LCD screen from its housing.
    • Lay the LCD screen flat on the keyboard.
  11. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 11, Bild 1 von 1
    • Disconnect the cable which connects the LCD to the motherboard.
    • Pul the LCD screen out.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G4, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 18
Letzte 30 Tage: 51
Insgesamt: 1,200
