Zum Hauptinhalt wechseln
HP Envy Sleekbook m6-k010dx LCD Replacement
Was du brauchst
    1. HP Envy Sleekbook m6-k010dx LCD Replacement, Battery: Schritt 1, Bild 1 von 1
      • Remove the twelve 9 mm Phillips #00 screws.
      Frag FixBot
      Kommentar hinzufügen
    2. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 2, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 2, Bild 2 von 2
      • Use the plastic opening tool and your hands to remove the bottom cover.
      Frag FixBot
    3. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 3, Bild 1 von 1
      • Disconnect the battery power cable from the motherboard.
      Frag FixBot
    4. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 4, Bild 1 von 1
      • Remove the six 6 mm Phillips #00 screws from the battery.
      Frag FixBot
    5. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 5, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 5, Bild 2 von 2
      • Lift the battery out of the laptop.
      Frag FixBot
    1. HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: Schritt 6, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement, LCD: Schritt 6, Bild 2 von 2
      • Remove the stickers from the bottom left and right corner of the device with a plastic opening tool.
      Frag FixBot
    2. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 7, Bild 1 von 1
      • Remove the two 2.5mm Phillips #00 screws found underneath the previously removed stickers.
      Frag FixBot
    3. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 8, Bild 1 von 3 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 8, Bild 2 von 3 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 8, Bild 3 von 3
      • Use the plastic opening tool to pry the bezel free from the LCD housing.
      Frag FixBot
    4. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 9, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 9, Bild 2 von 2
      • Remove the four 2.5mm Phillips #00 screws located in each corner of the LCD screen.
      Frag FixBot
    5. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 10, Bild 1 von 2 HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 10, Bild 2 von 2
      • Use the plastic opening tool to remove the LCD screen from its housing.
      • Lay the LCD screen flat on the keyboard.
      Frag FixBot
    6. HP Envy Sleekbook m6-k010dx LCD Replacement: Schritt 11, Bild 1 von 1
      • Disconnect the cable which connects the LCD to the motherboard.
      • Pul the LCD screen out.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G4, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Mitglieder
60 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 35
Insgesamt: 1,306
